Ir para o conteúdo principal
Nikon Coolpix S8200 CCD Lens Replacement
O que você precisa
  1. Nikon Coolpix S8200 CCD Lens Replacement, CCD Lens: passo 1, imagem 1 %32
    • First you must unscrew the back case by removing the two screws found on the bottom left and right of the camera as shown in the image.
    • Be careful not to remove any extra screws.
  2. Nikon Coolpix S8200 CCD Lens Replacement: passo 2, imagem 1 %32
    • Once the back is removed, Do Not remove the ribbon cables shown in the within the red circles on the image.
  3. Nikon Coolpix S8200 CCD Lens Replacement: passo 3, imagem 1 %32
    • Unscrew the two screws around the silver disk-like part indicated by the red circles on the image and then remove them.
    • Next gently remove the black strap indicated by the yellow circle on the image.
    • The black strap can easily snap back on for reassembly.
Conclusão
Uma outra pessoa concluiu este guia.
Nelson Antiposti
Membro desde: 03/25/15
499 Reputação
Autoria de 3 guias
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 33
Ao todo: 2,350
