Ir para o conteúdo principal
Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide
O que você precisa
  1. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: passo 1, imagem 1 %32 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide, Back Panel/Touch Screen: passo 1, imagem 2 %32
    • Remove all 4 screws from the bottom face of the camera using a Phillips #00 head screwdriver (found in iFixit tool kit).
  2. Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: passo 2, imagem 1 %32 Nikon Coolpix S800c Back Panel/Touch Screen Replacement Guide: passo 2, imagem 2 %32
    • Using a plastic tool, pry open the back panel of the camera. Be careful not to apply too much force and damage the camera.
Conclusão
Ilyasah Muhammad
Membro desde: 01/30/18
234 Reputação
Autoria de 2 guias
Equipe
Baylor, Team S2-G6, Johnson Spring 2018 Membro de Baylor, Team S2-G6, Johnson Spring 2018
BU-JOHNSON-S18S2G6
3 Membros
Autoria de 10 guias
1Comentário do guia
Many steps missing!! There are TWO more screws than the guide tells you about. Plus there’s no mention that after you finally get the camera split, you can’t just tug it apart—the motherboard is attached to the LCD. This guide is about worse than none at all!!
Brian Capouch - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 8
Ao todo: 644
