Ir para o conteúdo principal
Nikon Coolpix S7000 Sticky Button Replacement
O que você precisa
    • Clean your camera buttons. This can be done using isopropyl alcohol and a cotton swab. If the button is still jammed, proceed to Step 2.
  1. Nikon Coolpix S7000 Sticky Button Replacement: passo 2, imagem 1 %32 Nikon Coolpix S7000 Sticky Button Replacement: passo 2, imagem 2 %32 Nikon Coolpix S7000 Sticky Button Replacement: passo 2, imagem 3 %32
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • 3.2mm screws (not fully threaded)
    • 3mm screws
    • 4.2mm screws (coarser thread)
  2. Nikon Coolpix S7000 Sticky Button Replacement: passo 3, imagem 1 %32 Nikon Coolpix S7000 Sticky Button Replacement: passo 3, imagem 2 %32
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Sticky Button Replacement: passo 4, imagem 1 %32 Nikon Coolpix S7000 Sticky Button Replacement: passo 4, imagem 2 %32 Nikon Coolpix S7000 Sticky Button Replacement: passo 4, imagem 3 %32
    • At this point push out any buttons that were jammed, and, clean the inside portion where the button sits inside the frames with isopropyl alcohol and a cotton swab as moisture may have found its way inside the camera causing stickiness.
    • Swab this portion.
  4. Nikon Coolpix S7000 Sticky Button Replacement: passo 5, imagem 1 %32
    • If the navigation button is stuck, twist it around while the frame is removed to see if you can locate any obstructions.
    • If the shutter button is stuck, press up against it from the inside with your finger or the screwdriver to dislodge it.
  5. Nikon Coolpix S7000 Sticky Button Replacement: passo 6, imagem 1 %32
Conclusão
Uma outra pessoa concluiu este guia.
Shannon Beane
Membro desde: 01/10/17
324 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S2-G3, Lacy Spring 2017 Membro de USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 13
Duração total: 2,473
