Ir para o conteúdo principal
Nikon Coolpix S7000 Shutter Button Replacement
O que você precisa
  1. Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: passo 1, imagem 1 %32 Nikon Coolpix S7000 Shutter Button Replacement, Shutter Button: passo 1, imagem 2 %32
    • Remove the outer frame of the camera by unscrewing the screws around its sides with a JIS J000 screwdriver.
    • Screw locations.
  2. Nikon Coolpix S7000 Shutter Button Replacement: passo 2, imagem 1 %32 Nikon Coolpix S7000 Shutter Button Replacement: passo 2, imagem 2 %32
    • Remove outer camera frames by carefully pulling the frame apart from the body of the camera.
  3. Nikon Coolpix S7000 Shutter Button Replacement: passo 3, imagem 1 %32 Nikon Coolpix S7000 Shutter Button Replacement: passo 3, imagem 2 %32
    • Once the shutter button assembly is removed from the camera shell, carefully remove the black tape on the underside of the metal plate.
    • Black tape.
    • Do not discard the tape as you will reapply it when putting the shutter assembly back together.
  4. Nikon Coolpix S7000 Shutter Button Replacement: passo 4, imagem 1 %32 Nikon Coolpix S7000 Shutter Button Replacement: passo 4, imagem 2 %32 Nikon Coolpix S7000 Shutter Button Replacement: passo 4, imagem 3 %32
    • Unscrew the two screws on each side of the metal plate to remove the plate and springs underneath it.
    • Push the button through the assembly to release it and then carefully remove the button cover to reveal the coiled spring and bottom cover.
    • Locations of the two screws.
    • Be very careful not to lose the two metal plate springs and the coiled spring when disassembling. A slow and steady hand will help prevent the springs from ejecting.
Conclusão
Equipe
USF Tampa, Team S2-G3, Lacy Spring 2017 Membro de USF Tampa, Team S2-G3, Lacy Spring 2017
USFT-LACY-S17S2G3
Membros da 4
Autoria de 10 guias
Um comentário
shutter keeps trying to open. clicks slighly and does not open
Beatrix - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 772
