Ir para o conteúdo principal
Nikon Coolpix S70 Display Screen Replacement
O que você precisa
  1. Nikon Coolpix S70 Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Nikon Coolpix S70 Display Screen Replacement, Display Screen: passo 1, imagem 2 %32
    • Power off the camera before beginning.
    • Remove the battery by sliding the latch located at the bottom of the camera.
  2. Nikon Coolpix S70 Display Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix S70 Display Screen Replacement: passo 2, imagem 2 %32
    • Using a Phillips head #000 screwdriver, remove the five 0.4mm screws on the bottom of the camera.
  3. Nikon Coolpix S70 Display Screen Replacement: passo 3, imagem 1 %32 Nikon Coolpix S70 Display Screen Replacement: passo 3, imagem 2 %32 Nikon Coolpix S70 Display Screen Replacement: passo 3, imagem 3 %32
    • Use a plastic opening tool to carefully separate the back panel of the camera.
    • Once loosened, use your fingers to manually separate the two panels.
  4. Nikon Coolpix S70 Display Screen Replacement: passo 4, imagem 1 %32 Nikon Coolpix S70 Display Screen Replacement: passo 4, imagem 2 %32 Nikon Coolpix S70 Display Screen Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, lift both latches that hold the ribbon cables in place.
  5. Nikon Coolpix S70 Display Screen Replacement: passo 5, imagem 1 %32
    • Carefully disconnect the orange flat ribbon cables from the latches.
  6. Nikon Coolpix S70 Display Screen Replacement: passo 6, imagem 1 %32 Nikon Coolpix S70 Display Screen Replacement: passo 6, imagem 2 %32 Nikon Coolpix S70 Display Screen Replacement: passo 6, imagem 3 %32
    • Remove the screen from the case of the camera by carefully pushing on the back of the screen.
    • You may need to push with a little force to get the screen to loosen.
Conclusão
4 outras pessoas executaram este guia.
Equipe
Texas Tech, Team 22-2, Rauch Fall 2015 Membro de Texas Tech, Team 22-2, Rauch Fall 2015
TTU-RAUCH-F15S22G2
Membros da 3
1 Guia de autoria
Um comentário
my camera's lens show blury photos and when zooming id makes sound
Aliudin Saleh - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 18
Duração total: 1,107
