Ir para o conteúdo principal
Nikon Coolpix S6300 Polarizing Lens Replacement
O que você precisa
  1. Nikon Coolpix S6300 Polarizing Lens Replacement, Battery: passo 1, imagem 1 %32
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 2, imagem 1 %32
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Polarizing Lens Replacement, Buttons: passo 3, imagem 1 %32 Nikon Coolpix S6300 Polarizing Lens Replacement, Buttons: passo 3, imagem 2 %32 Nikon Coolpix S6300 Polarizing Lens Replacement, Buttons: passo 3, imagem 3 %32
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 4, imagem 1 %32 Nikon Coolpix S6300 Polarizing Lens Replacement: passo 4, imagem 2 %32 Nikon Coolpix S6300 Polarizing Lens Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 6, imagem 1 %32
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 7, imagem 1 %32
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Polarizing Lens Replacement, Display: passo 8, imagem 1 %32
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
  9. Nikon Coolpix S6300 Polarizing Lens Replacement, Polarizing Lens: passo 9, imagem 1 %32 Nikon Coolpix S6300 Polarizing Lens Replacement, Polarizing Lens: passo 9, imagem 2 %32 Nikon Coolpix S6300 Polarizing Lens Replacement, Polarizing Lens: passo 9, imagem 3 %32
    • Remove the four PH00 2.5 mm screws around the edges of the display plate.
    • Remove the three PH00 2 mm screws from the sides of the buttons plate and the 2.5 mm screw from the center of the buttons plate.
    • Lift the buttons plate out of the camera with the plastic tool.
    • Lift the display plate out of the camera with the plastic tool.
  10. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 10, imagem 1 %32 Nikon Coolpix S6300 Polarizing Lens Replacement: passo 10, imagem 2 %32 Nikon Coolpix S6300 Polarizing Lens Replacement: passo 10, imagem 3 %32
    • Use the plastic opening tool to gently flip the white folders at the end of the ribbon cables.
    • Use this tweezers to gently pull the cables out of the holders.
    • Lift the lens apparatus out of the rest of the camera by pushing the front of lens up from the bottom.
  11. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 11, imagem 1 %32 Nikon Coolpix S6300 Polarizing Lens Replacement: passo 11, imagem 2 %32
    • Use the plastic opening tool to flip the two white clips holding the ribbon cables.
    • Use tweezers to pull the cables from clamps.
    • Use the PH00 screwdriver to remove the three 2 mm screws around the first lens area.
  12. Nikon Coolpix S6300 Polarizing Lens Replacement: passo 12, imagem 1 %32 Nikon Coolpix S6300 Polarizing Lens Replacement: passo 12, imagem 2 %32
    • Lift the first lens from the rest of the lens apparatus.
    • Use thin tweezers to left and remove the polarizing lens from the apparatus.
Conclusão
Uma outra pessoa concluiu este guia.
Michael Lynch
Membro desde: 08/31/15
396 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-2, Remmell Fall 2015 Membro de USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
Membros da 5
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 27
Duração total: 960
