Ir para o conteúdo principal
Nikon Coolpix S6300 Display Replacement
O que você precisa
  1. Nikon Coolpix S6300 Display Replacement, Battery: passo 1, imagem 1 %32
    • Place the camera facing upwards.
    • Press down on the battery cover and slide towards the front face of the camera.
  2. Nikon Coolpix S6300 Display Replacement: passo 2, imagem 1 %32
    • Rotate the orange battery clip in the camera to release the battery.
  3. Nikon Coolpix S6300 Display Replacement, Buttons: passo 3, imagem 1 %32 Nikon Coolpix S6300 Display Replacement, Buttons: passo 3, imagem 2 %32 Nikon Coolpix S6300 Display Replacement, Buttons: passo 3, imagem 3 %32
    • Locate the eight outer PH 2mm screws on the device.
    • Using the PH00 screwdriver remove all of the screws from the camera.
  4. Nikon Coolpix S6300 Display Replacement: passo 4, imagem 1 %32 Nikon Coolpix S6300 Display Replacement: passo 4, imagem 2 %32 Nikon Coolpix S6300 Display Replacement: passo 4, imagem 3 %32
    • Using a plastic opening tool, gently pry off the front and rear plates.
    • Be patient with this step, do not force the clips holding the plates together.
  5. Nikon Coolpix S6300 Display Replacement: passo 5, imagem 1 %32
    • Using a Phillips #00 screwdriver, remove the PH 2mm screw located to the right of the screen, above the OK dial.
  6. Nikon Coolpix S6300 Display Replacement: passo 6, imagem 1 %32
    • Remove the two clasp using a plastic spudger
    • Be careful when removing the clasp to prevent ripping of the clasp
  7. Nikon Coolpix S6300 Display Replacement: passo 7, imagem 1 %32
    • You may now remove the internal panel of the buttons
  8. Nikon Coolpix S6300 Display Replacement, Display: passo 8, imagem 1 %32
    • Remove the clasp from the ribbon cable using the plastic spudger.
    • Make sure to be gentle when removing the clasp to prevent it from ripping.
    • You may now remove the display.
Conclusão
Hung
Membro desde: 09/01/15
383 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-2, Remmell Fall 2015 Membro de USF Tampa, Team 1-2, Remmell Fall 2015
USFT-REMMELL-F15S1G2
Membros da 5
Autoria de 10 guias
2 comentários
Step 8 could have better pictures and explanation of the clasp...or picture of the clasp. I think it was some white tape looking stuff that I did break. Looking for better instructions elsewhere. I think I just made the situation worse
Lisa F - Responder
I have this problem with my coolpix (see images and video):
https://i.postimg.cc/pXk2L4QB/20190201-1...
https://i.postimg.cc/d3wYqjLX/20190201-1...
https://i.postimg.cc/RCLmgyYz/20190201-1...
https://drive.google.com/file/d/1sDr8fPD...
Screen has a posterized effect.
I already replaced the screen with a new one, but the problem remains..
Any idea what is faulty, and how can I fix it?
Geo Nik - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 18
Duração total: 1,416
