Ir para o conteúdo principal
Nikon Coolpix S630 Shutter Button Replacement
O que você precisa
  1. Nikon Coolpix S630 Shutter Button Replacement, Battery Compartment: passo 1, imagem 1 %32
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Shutter Button Replacement, Battery: passo 2, imagem 1 %32
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Shutter Button Replacement, Memory Card: passo 3, imagem 1 %32
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Shutter Button Replacement, Front Cover: passo 4, imagem 1 %32
    • Locate a small, rectangular flap above the battery cover door.
    • Push the small, rectangular flap back through the hole.
  5. Nikon Coolpix S630 Shutter Button Replacement: passo 5, imagem 1 %32
    • Using the plastic opening tool, gently pry open the front cover. Gently remove the front cover.
    • Make sure to hold the camera down when removing the front cover.
  6. Nikon Coolpix S630 Shutter Button Replacement, Shutter Button: passo 6, imagem 1 %32
    • Place the front cover facing down so that you can easily see the shutter button.
  7. Nikon Coolpix S630 Shutter Button Replacement: passo 7, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using tweezers, gently slide the shutter button out.
    • Be very gentle because you can damage the piece.
Conclusão
Equipe
Cal Poly, Team 8-56, Johann Spring 2013 Membro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 2,227
