Ir para o conteúdo principal
Nikon Coolpix S630 Lens Replacement
O que você precisa
  1. Nikon Coolpix S630 Lens Replacement, Battery Compartment: passo 1, imagem 1 %32
    • The battery compartment is located on the bottom of the camera.
    • Place your thumb on the battery door.
    • Slide the door away from the camera in the direction the arrow points to.
  2. Nikon Coolpix S630 Lens Replacement, Battery: passo 2, imagem 1 %32
    • Slide the yellow tab towards the back of the camera.
    • The battery should pop out.
    • Remove the battery.
  3. Nikon Coolpix S630 Lens Replacement, Memory Card: passo 3, imagem 1 %32
    • Press the memory card down into the camera.
    • The memory card should pop out.
    • Remove the memory card.
  4. Nikon Coolpix S630 Lens Replacement, Back Cover Removal: passo 4, imagem 1 %32 Nikon Coolpix S630 Lens Replacement, Back Cover Removal: passo 4, imagem 2 %32 Nikon Coolpix S630 Lens Replacement, Back Cover Removal: passo 4, imagem 3 %32
    • Unscrew the two 3.5mm Phillips screws from the side with the AV outlet.
    • Unscrew the 3.5mm Phillips screw from the opposite side of the camera.
    • Unscrew the six 3.5mm Phillips screws from the bottom of the camera.
  5. Nikon Coolpix S630 Lens Replacement: passo 5, imagem 1 %32
    • Carefully remove the back casing from the camera.
    • Be mindful when removing the back casing as there is a ribbon that still connects the back casing to the motherboard.
  6. Nikon Coolpix S630 Lens Replacement, Detaching Ribbon: passo 6, imagem 1 %32 Nikon Coolpix S630 Lens Replacement, Detaching Ribbon: passo 6, imagem 2 %32
    • Place the plastic opening tool underneath the ribbon tab as shown. Gently lift the tab up.
    • Gently pull the ribbon from the logic board with tweezers.
    • With the ribbon disconnected, the back casing should now be detached from the rest of the camera.
  7. Nikon Coolpix S630 Lens Replacement, Lens: passo 7, imagem 1 %32
    • Remove the metal casing from the logic board.
    • There are three ribbons that connect the lens to the logic board as shown.
    • Place the flat end of the spudger underneath one of the black flaps. Carefully lift the flap with the spudger and gently slide the ribbon out.
    • Repeat the above process to remove the remaining two ribbons.
  8. Nikon Coolpix S630 Lens Replacement: passo 8, imagem 1 %32
    • Unscrew the four, 3.5mm Phillips screws that hold down the metal plate.
  9. Nikon Coolpix S630 Lens Replacement: passo 9, imagem 1 %32 Nikon Coolpix S630 Lens Replacement: passo 9, imagem 2 %32 Nikon Coolpix S630 Lens Replacement: passo 9, imagem 3 %32
    • Carefully lift the lens off of the front cover.
Conclusão
Equipe
Cal Poly, Team 8-56, Johann Spring 2013 Membro de Cal Poly, Team 8-56, Johann Spring 2013
CPSU-JOHANN-S13S8G56
Membros da 4
Autoria de 18 guias
Um comentário
Between steps 6 and 7 there should be a step to remove the LCD screen, metal casing and ribbon cables.
There is a 5th screw required to remove the lens in step 8. It’s under the fat ribbon cable. Deep in a hole.
Rob G - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 7
Duração total: 1,689
