Ir para o conteúdo principal
Nikon Coolpix S5300 Lens Replacement
O que você precisa
  1. Nikon Coolpix S5300 Lens Replacement, Battery: passo 1, imagem 1 %32
    • Turn the camera upside down and locate the battery compartment.
    • Slide the compartment open following the direction of the arrow.
  2. Nikon Coolpix S5300 Lens Replacement: passo 2, imagem 1 %32
    • Press the orange release button to release and remove the battery.
    • Replace or insert battery in it's respective terminals
  3. Nikon Coolpix S5300 Lens Replacement, Outer Casing: passo 3, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement, Outer Casing: passo 3, imagem 2 %32 Nikon Coolpix S5300 Lens Replacement, Outer Casing: passo 3, imagem 3 %32
    • Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
    • Using the same screwdriver, remove the 2 screws on the side of the camera.
    • Remove the 2 screws from the other side of the camera.
    • One of the screws is under the I/O port cover.
  4. Nikon Coolpix S5300 Lens Replacement: passo 4, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 4, imagem 2 %32 Nikon Coolpix S5300 Lens Replacement: passo 4, imagem 3 %32
    • Use the plastic opening tool to carefully separate the cover from the camera.
    • Work the plastic opening tool around all the edges of the front plate.
    • Pull the purple plastic cover off gently from the screen.
  5. Nikon Coolpix S5300 Lens Replacement: passo 5, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 5, imagem 2 %32 Nikon Coolpix S5300 Lens Replacement: passo 5, imagem 3 %32
    • Turn the camera over so the LCD screen is facing you.
    • Carefully remove the front shell by gently prying around the corners with the plastic opening tool until it releases.
  6. Nikon Coolpix S5300 Lens Replacement: passo 6, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 6, imagem 2 %32
    • Be careful to keep track of little pieces of the outside casing.
  7. Nikon Coolpix S5300 Lens Replacement: passo 7, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 7, imagem 2 %32
    • Carefully remove the top button casing by pulling it away from main camera.
  8. Nikon Coolpix S5300 Lens Replacement, Button Panel: passo 8, imagem 1 %32
    • Remove the 2 screws on the silver plate
    • Gently lift the screen and silver plate away from the internal components.
    • Do not separate the plate and screen from the camera
  9. Nikon Coolpix S5300 Lens Replacement: passo 9, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 9, imagem 2 %32
    • Carefully move the button panel away from the silver plate.
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap.
    • Safely pull the ribbon cable out and then remove the button panel.
    • Be sure you are prying up on the hinged retaining flap, not the connector itself.
  10. Nikon Coolpix S5300 Lens Replacement, LCD Display Screen: passo 10, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement, LCD Display Screen: passo 10, imagem 2 %32
    • Carefully remove the screen away from the silver plate.
    • Carefully fold the screen over exposing the latch for the ribbon cable.
  11. Nikon Coolpix S5300 Lens Replacement: passo 11, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 11, imagem 2 %32 Nikon Coolpix S5300 Lens Replacement: passo 11, imagem 3 %32
    • To disconnect the ribbon cable, use the tip of a plastic opening tool or your fingernail to flip up the small retaining flap. Then, you can safely pull the ribbon cable out.
  12. Nikon Coolpix S5300 Lens Replacement: passo 12, imagem 1 %32
    • Once the ribbon cable is disconnected, remove the LCD screen.
  13. Nikon Coolpix S5300 Lens Replacement, Image Sensor: passo 13, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement, Image Sensor: passo 13, imagem 2 %32
    • Using the phillips head screwdriver, remove the three 0.1mm screws on the metal plate.
    • Carefully remove metal plate from the camera.
  14. Nikon Coolpix S5300 Lens Replacement: passo 14, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement: passo 14, imagem 2 %32 Nikon Coolpix S5300 Lens Replacement: passo 14, imagem 3 %32
    • Use the plastic opening tool or your finger nail to carefully flip up the ribbon cable retaining flap.
    • Use the same screwdriver to remove the three 3mm screws that were revealed after removing the metal plate.
  15. Nikon Coolpix S5300 Lens Replacement: passo 15, imagem 1 %32
    • Gently pull the ribbon cable to remove the image sensor.
  16. Nikon Coolpix S5300 Lens Replacement, Lens: passo 16, imagem 1 %32 Nikon Coolpix S5300 Lens Replacement, Lens: passo 16, imagem 2 %32 Nikon Coolpix S5300 Lens Replacement, Lens: passo 16, imagem 3 %32
    • Be sure you are prying up on the black hinged retaining flap, not the connector itself.
    • Carefully push the lens towards you until it is almost removed from the chamber.
    • Remove the lens assembly from the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Riordan McCole
Membro desde: 03/04/16
307 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team 6-1, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 6-1, Bhusal Spring 2016
UMASSD-BHUSAL-S16S6G1
Membros da 3
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 10
Duração total: 817
