Introdução
The purpose of this guide is to replace the LCD screen. This guide will provide the necessary information to:
- Disassemble the camera.
- Replace the screen.
- Properly reassemble the components involved.
O que você precisa
Turn the camera upside down and locate the battery compartment.
Slide the compartment open following the direction of the arrow.
Remove the four 0.1mm screws from the bottom of the camera using the phillips head screwdriver
Using the same screwdriver, remove the 2 screws on the side of the camera.
Remove the 2 screws from the other side of the camera.
Remove the 2 screws on the silver plate
Gently lift the screen and silver plate away from the internal components.
Carefully remove the screen away from the silver plate.
Carefully fold the screen over exposing the latch for the ribbon cable.
