Ir para o conteúdo principal
Nikon Coolpix S5200 LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: passo 1, imagem 2 %32 Nikon Coolpix S5200 LCD Screen Replacement, LCD Screen: passo 1, imagem 3 %32
    • There are four 0.1 mm screws holding the front and back of the camera together all along the outside of the camera
    • There should be four screws
  2. Nikon Coolpix S5200 LCD Screen Replacement: passo 2, imagem 1 %32
    • Use the Phillips Head screw driver head to remove the four 0.1 mm screws surrounding the outer edges of the camera
  3. Nikon Coolpix S5200 LCD Screen Replacement: passo 3, imagem 1 %32
    • Pull the plastic back cover off of and away from the LCD screen
  4. Nikon Coolpix S5200 LCD Screen Replacement: passo 4, imagem 1 %32
    • Carefully remove the LCD screen from the silver plate that once held it in place by pulling it away from the internal components
  5. Nikon Coolpix S5200 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the six designated screws sized 0.1 mm from the metal plate using a Phillip's Head screwdriver in size PH00.
  6. Nikon Coolpix S5200 LCD Screen Replacement: passo 6, imagem 1 %32
    • Lift the metal plate away from the internal components of the camera
  7. Nikon Coolpix S5200 LCD Screen Replacement: passo 7, imagem 1 %32 Nikon Coolpix S5200 LCD Screen Replacement: passo 7, imagem 2 %32
    • Carefully remove the LCD screen by pulling it away from the camera. Repeat these steps in reverse order to install the new LCD screen.
Conclusão
Andy Powers
Membro desde: 09/22/15
391 Reputação
Autoria de 3 guias
Um comentário
Shouldn't the replacement LCD screen be considered a part? It is in fact very difficult to replace it without having the part to replace.
joshronsen - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Duração total: 1,072
