Introdução
You will need a #00 phillip's head screwdriver and a black spudger (or equivalent tool).
O que você precisa
Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
Remove the five screws on the metal plate.
Remove the screw at the bottom of the camera.
Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
Lift two flaps with the spudger on the top of the motherboard to release ribbons.
