Ir para o conteúdo principal
Nikon Coolpix S51c Motherboard Replacement
O que você precisa
  1. Nikon Coolpix S51c Motherboard Replacement, Back Cover: passo 1, imagem 1 %32 Nikon Coolpix S51c Motherboard Replacement, Back Cover: passo 1, imagem 2 %32
    • Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
  2. Nikon Coolpix S51c Motherboard Replacement: passo 2, imagem 1 %32
    • Open the battery door by sliding it in the direction of the arrow to reveal a hidden screw on the opposite side of the orange lever.
    • Remove this screw using a Phillips #00 screwdriver.
  3. Nikon Coolpix S51c Motherboard Replacement: passo 3, imagem 1 %32
    • Rotate the camera to find the side panel with the lanyard attachment.
    • Detach the side panel by the lifting bottom corner slightly with the spudger.
  4. Nikon Coolpix S51c Motherboard Replacement: passo 4, imagem 1 %32
    • Lift the back cover, being careful not to rip the orange cables between the camera and the back cover.
  5. Nikon Coolpix S51c Motherboard Replacement: passo 5, imagem 1 %32
    • With the back cover lifted, lift the black flap that connects the ribbon to the motherboard with the spudger and carefully remove the back cover.
  6. Nikon Coolpix S51c Motherboard Replacement, Lens: passo 6, imagem 1 %32 Nikon Coolpix S51c Motherboard Replacement, Lens: passo 6, imagem 2 %32 Nikon Coolpix S51c Motherboard Replacement, Lens: passo 6, imagem 3 %32
    • Remove the five screws on the metal plate.
    • One of them is in a hole in the corner of the metal plate.
    • Remove the screw at the bottom of the camera.
    • Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
  7. Nikon Coolpix S51c Motherboard Replacement: passo 7, imagem 1 %32 Nikon Coolpix S51c Motherboard Replacement: passo 7, imagem 2 %32
    • Lift the white flap with the spudger to release the ribbon.
    • Remove the back metal plate.
  8. Nikon Coolpix S51c Motherboard Replacement: passo 8, imagem 1 %32 Nikon Coolpix S51c Motherboard Replacement: passo 8, imagem 2 %32 Nikon Coolpix S51c Motherboard Replacement: passo 8, imagem 3 %32
    • Lift the two ribbons with the spudger to disconnect the lens and pull it out.
  9. Nikon Coolpix S51c Motherboard Replacement, Motherboard: passo 9, imagem 1 %32 Nikon Coolpix S51c Motherboard Replacement, Motherboard: passo 9, imagem 2 %32
    • Lift two flaps with the spudger on the top of the motherboard to release ribbons.
  10. Nikon Coolpix S51c Motherboard Replacement: passo 10, imagem 1 %32 Nikon Coolpix S51c Motherboard Replacement: passo 10, imagem 2 %32
    • lift motherboard from the top to remove it from the camera.
Conclusão
Ryan
Membro desde: 04/12/11
155 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 18-24, Garner Spring 2011 Membro de Cal Poly, Team 18-24, Garner Spring 2011
CPSU-GARNER-S11S18G24
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 1,799
