Introdução
If your Nikon Coolpix S51c camera is producing photos that are blurry or show scratches or marks on the photo, the camera lens may be damaged. You can replace the camera lens by following this guide.
Disconnect your camera from its charger before starting this repair. There are delicate ribbons and wires inside the camera, so be careful not to rip them.
O que você precisa
Remove all five screws from the bottom of the camera using a Phillips #00 screwdriver.
Remove the five screws on the metal plate.
Remove the screw at the bottom of the camera.
Carefully lift the metal plate from the right side to reveal a ribbon connected to the motherboard.
Uma outra pessoa concluiu este guia.
2 comentários
question: any source for replacement lens block ? can't find any on the internet
question: any source for lens block ? I can't find any on the internet
