Ir para o conteúdo principal
Nikon Coolpix S4000 Speaker Replacement
O que você precisa
  1. Nikon Coolpix S4000 Speaker Replacement, Battery: passo 1, imagem 1 %32
    • Slide the battery door open with a finger or thumb and release it so the door opens.
  2. Nikon Coolpix S4000 Speaker Replacement: passo 2, imagem 1 %32
    • Push the orange tab back and the battery will pop out.
  3. Nikon Coolpix S4000 Speaker Replacement, Casing: passo 3, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement, Casing: passo 3, imagem 2 %32 Nikon Coolpix S4000 Speaker Replacement, Casing: passo 3, imagem 3 %32
    • Remove four 2mm Phillips #000 screws.
    • Remove two black 3mm Phillips #000 screws.
    • Remove one 4mm Phillips #000 screws.
    • Remove two silver 3mm Phillips #000 screws.
  4. Nikon Coolpix S4000 Speaker Replacement: passo 4, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 4, imagem 2 %32
    • Use your fingers, or a spudger, to lift up one end of the casing and then pry the two pieces apart.
  5. Nikon Coolpix S4000 Speaker Replacement: passo 5, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 5, imagem 2 %32 Nikon Coolpix S4000 Speaker Replacement: passo 5, imagem 3 %32
    • Turn the camera over.
    • Use your fingers, or spudger, to lift one end of the back casing and pry it apart from back of the camera.
  6. Nikon Coolpix S4000 Speaker Replacement, Lens Casing: passo 6, imagem 1 %32
    • Remove the single 3mm Phillips #000 screw from the back of the camera.
  7. Nikon Coolpix S4000 Speaker Replacement: passo 7, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 7, imagem 2 %32
    • Turn the camera over and pry the lens casing off by slipping your fingers, or spudger, under the lip of the casing.
    • Desolder the two wires connecting the casing to the motherboard.
    • Work carefully so that you do not break the soldered wires.
  8. Nikon Coolpix S4000 Speaker Replacement, Screen: passo 8, imagem 1 %32
    • Remove the single 2mm Phillips #000 screw.
  9. Nikon Coolpix S4000 Speaker Replacement: passo 9, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 9, imagem 2 %32 Nikon Coolpix S4000 Speaker Replacement: passo 9, imagem 3 %32
    • Use the flat end of a spudger to lift up the black tabs on the ZIF connectors.
    • Pull the ribbon cables out of the ZIF connectors.
  10. Nikon Coolpix S4000 Speaker Replacement: passo 10, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 10, imagem 2 %32
    • Grabbing the top left corner of the screen, pull it up until the screen comes completely off.
  11. Nikon Coolpix S4000 Speaker Replacement, Lens: passo 11, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement, Lens: passo 11, imagem 2 %32
    • Remove the two 3mm Phillips #000 screws.
  12. Nikon Coolpix S4000 Speaker Replacement: passo 12, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 12, imagem 2 %32
    • Turn the camera over and remove a single 4mm Phillips #000 screw.
    • There may be black tape covering the screw.
  13. Nikon Coolpix S4000 Speaker Replacement: passo 13, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 13, imagem 2 %32
    • Use the flat end of a spudger to flip up the black tabs on the ZIF connectors.
  14. Nikon Coolpix S4000 Speaker Replacement: passo 14, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement: passo 14, imagem 2 %32
    • Use the flat end of a spudger to pry the lens locking tabs open while pulling the lens away from the camera body.
    • The tabs are brittle so use gently force.
  15. Nikon Coolpix S4000 Speaker Replacement: passo 15, imagem 1 %32
    • Use the flat end of a spudger to lift up the black tab on the ZIF connector.
    • Pull the orange ribbon cable out of the ZIF connector.
    • Separate the lens from the motherboard.
  16. Nikon Coolpix S4000 Speaker Replacement, Speaker: passo 16, imagem 1 %32 Nikon Coolpix S4000 Speaker Replacement, Speaker: passo 16, imagem 2 %32
    • Slide the speaker out from the bottom of the speaker piece.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Duração total: 120
