Introdução
A bit of a fumble can result in a screen shattered beyond use, especially with a device this fragile. Or maybe the screen has some internal damage that has made it unresponsive to touch. Either way, this guide will help you replace the screen with minimal adjustment to the other parts.
O que você precisa
Slide the battery door open with a finger or thumb and release it so the door opens.
Remove four 2mm Phillips #000 screws.
Remove two black 3mm Phillips #000 screws.
Remove one 4mm Phillips #000 screws.
Remove two silver 3mm Phillips #000 screws.
