Introdução
If the sound in your camera is distorted or there is no sound in videos, the speaker may need to be replaced. This guide will show how to remove the speaker and insert a new one.
O que você precisa
Remove all four T5 Torx screws from the exterior of the camera.
Remove all three T5 Torx screws located at the bottom of the camera next to the battery compartment.
Using a plastic opening tool, pry the LCD screen out of its slot inside of the camera.
Remove the screws. Gently pry off the LCD holder using a plastic opening tool.
