Ir para o conteúdo principal
Nikon Coolpix S33 Battery and SD Card Replacement
O que você precisa
  1. Nikon Coolpix S33  Battery and SD Card Replacement, Battery and SD Card: passo 1, imagem 1 %32 Nikon Coolpix S33  Battery and SD Card Replacement, Battery and SD Card: passo 1, imagem 2 %32
    • Make sure that your camera is turned off before beginning any replacement of parts.
    • Flip the camera over to the Battery/SD Card compartment at the bottom right of your camera, located directly under the Coolpix logo.
    • This slot is for the camera's battery.
    • This slot is for the camera's SD card.
    • Open up the compartment of the camera as shown in the images.
    • No tools are necessary for this replacement.
    • Using your finger, push on the latch in the direction of the arrow to release the battery from the locking mechanism holding it in your camera.
    • Push down the SD card to release it from the locking mechanism in your camera.
    • Once the Battery and SD Card are loose, you can pull them out of their respective slots.
Conclusão
4 outras pessoas executaram este guia.
Equipe
USF Tampa, Team 16-3, Blackwell Winter 2016 Membro de USF Tampa, Team 16-3, Blackwell Winter 2016
USFT-BLACKWELL-W16S16G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 98
Duração total: 3,705
