Ir para o conteúdo principal
Nikon Coolpix S3100 disassembly
O que você precisa
  1. Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: passo 1, imagem 1 %32 Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: passo 1, imagem 2 %32 Nikon Coolpix S3100 disassembly, Nikon Coolpix S3100 disassembly: passo 1, imagem 3 %32
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 disassembly: passo 2, imagem 1 %32 Nikon Coolpix S3100 disassembly: passo 2, imagem 2 %32
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 disassembly: passo 3, imagem 1 %32 Nikon Coolpix S3100 disassembly: passo 3, imagem 2 %32
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
Conclusão
Jorge
Membro desde: 03/11/15
1.170 Reputação
Autoria de 7 guias
Equipe
Colorado Springs, Team 2-4, Panko Spring 2015 Membro de Colorado Springs, Team 2-4, Panko Spring 2015
UCCS-PANKO-S15S2G4
Membros da 2
Autoria de 13 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 48
Duração total: 1,986
