Introdução
The shutter button seems to malfunction whether it is not turning or not working. This guide will help you understand the problem.
O que você precisa
Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
Remove 2 screws from left side. (picture 1)
Remove 4 screws from bottom. (picture 2)
Remove 2 screws from right side. (picture 3)
Turn and hold the shutter bottom to the left and using a tweezer carefully remove the spring.
Uma outra pessoa concluiu este guia.
