Ir para o conteúdo principal
Nikon Coolpix S3100 Camera Lens Replacement
O que você precisa
  1. Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: passo 1, imagem 1 %32 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: passo 1, imagem 2 %32 Nikon Coolpix S3100 Camera Lens Replacement, Nikon Coolpix S3100 disassembly: passo 1, imagem 3 %32
    • Remove 8-2.46 mm screws from both sides and bottom of camera using a #000 Phillips screwdriver.
    • Remove 2 screws from left side. (picture 1)
    • Remove 4 screws from bottom. (picture 2)
    • Remove 2 screws from right side. (picture 3)
  2. Nikon Coolpix S3100 Camera Lens Replacement: passo 2, imagem 1 %32 Nikon Coolpix S3100 Camera Lens Replacement: passo 2, imagem 2 %32
    • Remove black cover pulling up with left thumb. Hold silver cover with right thumb.
    • Remove silver cover lifting up with left thumb. Hold the camera with right thumb.
    • Once internal circuit board is exposed, the red and blue wire terminals at top center can provide a nasty shock from the charged flash capacitor (silver can to left of terminals). BE CAREFUL!
  3. Nikon Coolpix S3100 Camera Lens Replacement: passo 3, imagem 1 %32 Nikon Coolpix S3100 Camera Lens Replacement: passo 3, imagem 2 %32
    • Remove 2-2.10mm screws in the front of the camera using a #000 Phillips screwdriver.
    • Remove the two screws.
    • Gently pull up to detach the frame. (picture 2)
  4. Nikon Coolpix S3100 Camera Lens Replacement, LCD Screen: passo 4, imagem 1 %32
    • Remove 2-2.10mm screws using a #000 Phillips screwdriver.
  5. Nikon Coolpix S3100 Camera Lens Replacement: passo 5, imagem 1 %32
    • Gently pull the orange board to the right.
  6. Nikon Coolpix S3100 Camera Lens Replacement: passo 6, imagem 1 %32
    • Lift screen up holding both corners.
  7. Nikon Coolpix S3100 Camera Lens Replacement: passo 7, imagem 1 %32
    • Gently pull to the left to release from ZIF connector.
  8. Nikon Coolpix S3100 Camera Lens Replacement, Lens: passo 8, imagem 1 %32
    • Remove 4-2.10mm screws using a #000 Phillips screwdriver.
  9. Nikon Coolpix S3100 Camera Lens Replacement: passo 9, imagem 1 %32
    • Gently pull the shutter up.
  10. Nikon Coolpix S3100 Camera Lens Replacement: passo 10, imagem 1 %32
    • Remove 3-2.12mm screws using #000 Phillips screwdriver.
  11. Nikon Coolpix S3100 Camera Lens Replacement: passo 11, imagem 1 %32
    • Use a nylon or metal spudger to release the lens.
  12. Nikon Coolpix S3100 Camera Lens Replacement: passo 12, imagem 1 %32
    • Repeat step 4 to the opposite side of the lens.
  13. Nikon Coolpix S3100 Camera Lens Replacement: passo 13, imagem 1 %32
    • The lens is now separated.
Conclusão
11 outras pessoas executaram este guia.
Jorge
Membro desde: 03/11/15
1.170 Reputação
Autoria de 7 guias
Equipe
Colorado Springs, Team 2-4, Panko Spring 2015 Membro de Colorado Springs, Team 2-4, Panko Spring 2015
UCCS-PANKO-S15S2G4
Membros da 2
Autoria de 13 guias
6 comentários
My lens shutter does not open correctly. After turning the camera on, the shutter only half opens with a juddering motion. Any ideas?
Anita
William Dawson - Responder
Nikon coolpix s3100 lens mocking place help my
Nanji Buchiya - Responder
My lens shutter does not open correctly after turning on and after close with juddering repeatly how can be repaired
Bimolthou Thuodam - Responder
I have same issue it shutter half opens and doesnt open correctly
shailendra - Responder
my LCD screen is stuck on white after after i did this :(
andrew welles - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 48
Duração total: 4,131
