Ir para o conteúdo principal
Nikon Coolpix S220 Battery and Memory Card Replacement
O que você precisa
  1. Nikon Coolpix S220 Battery and Memory Card Replacement, Battery and Memory Card: passo 1, imagem 1 %32
    • Slide the battery and memory card cover (located on the bottom of the camera) to release it.
  2. Nikon Coolpix S220 Battery and Memory Card Replacement: passo 2, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • To release battery you must slide the orange hatch, once doing so the battery will pop up.
    • Remove with tweezers or your fingers.
  3. Nikon Coolpix S220 Battery and Memory Card Replacement: passo 3, imagem 1 %32
    • To release the memory card, simply push down on the memory card and it will pop up as the battery did.
    • You will be able to remove with your fingers.
Conclusão
Shauna
Membro desde: 04/05/11
798 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 12-32, Maness Spring 2011 Membro de Cal Poly, Team 12-32, Maness Spring 2011
CPSU-MANESS-S11S12G32
Membros da 4
Autoria de 10 guias
Um comentário
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
bonitakale - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 43
Duração total: 19,149
