Introdução
If the battery is dead or the memory card is full, it must be changed or charged. In order to accomplish either they must be removed. This guide will show the reader how to simply remove either one.
O que você precisa
Slide the battery and memory card cover (located on the bottom of the camera) to release it.
Um comentário
Thank you! If you're like me, the way you push the memory card registers as "in," not "down," but I got it out!
