Ir para o conteúdo principal
Introdução
The Nikon Coolpix P90 is only compatible with SD and SDHC memory cards. It is not compatible with Multi Media Cards (MMC).
  1. Use your finger to push the notch of the compartment door to the center of the camera body. Release the compartment door, and it will swing open. Remove the existing battery with your fingers.
    • Use your finger to push the notch of the compartment door to the center of the camera body.
    • Release the compartment door, and it will swing open.
    • Remove the existing battery with your fingers.
  2. Gently push the memory card down into the compartment until it clicks to unlock. Release and pull memory card out with your fingers. Release and pull memory card out with your fingers.
    • Gently push the memory card down into the compartment until it clicks to unlock.
    • Release and pull memory card out with your fingers.
Conclusão
Elizabeth Kamine
Membro desde: 22/01/2015
655 Reputação
6 Guias de autoria
Equipe
Cal Poly, Team 20-14, Maness Winter 2015 Membro de Cal Poly, Team 20-14, Maness Winter 2015
CPSU-MANESS-W15S20G14
4 Membros
7 Guias de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 367
