Introdução
The lens zoom unit aids in capturing images from a distance. This guide will provide the necessary instructions for replacing a broken or malfunctioning zoom lens unit.
O que você precisa
Remove the six 4mm screws highlighted in red with the Phillips #000 screwdriver.
Remove the 5mm screw highlighted in orange with the Phillips #000 screwdriver.
Pop up the camera flash using the button below the lightning bolt on the left side of the camera.
Identify the small notch below the camera flash where the body of the camera and the back cover join.
Use plastic opening tools to pry the darker plastic piece under the camera flash from the lighter plastic camera body.
Gently lift the back cover away from the camera body.
A gold ribbon cable will join the back cover of the camera to the internal electronic components. Be careful not to remove the back cover without removing the cable since this part can easily break.
To remove the ribbon cable, gently pull the connector from the camera's internal electronic components using a pair of tweezers.
Remove the six 4mm screws highlighted in red using the Philips #000 screwdriver.
Remove the 6mm screw highlighted in orange using the Philips #000 screwdriver.
Disconnect the ribbon cable connector by prying upwards on the part using the plastic opening tools.
Remove the four 7mm screws highlighted in red using the Philips #000 screwdriver.
5 outras pessoas executaram este guia.
Um comentário
Without this guide I would never have attempted to try and fix my "lens error" by disassembling my P520 Coolpix. There were a few more screws than the P530 instructions, but it was essentially the same. I could not fix my issue and I am not willing to invest in another lens, so my nice camera is now scrap. However, that is no reflection on these VERY GOOD step by step instructions and photos. thanks.... joe
