Ir para o conteúdo principal
Nikon Coolpix P530 Battery Replacement
O que você precisa
  1. Nikon Coolpix P530 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Identify the battery chamber found at the bottom of the device.
    • Ensure the camera is turned off before conducting any maintenance on the device.
  2. Nikon Coolpix P530 Battery Replacement: passo 2, imagem 1 %32 Nikon Coolpix P530 Battery Replacement: passo 2, imagem 2 %32 Nikon Coolpix P530 Battery Replacement: passo 2, imagem 3 %32
    • Slide the switch to the left to open the battery chamber using your fingertip or plastic opening tools.
    • The spring loaded battery chamber door will swing open after the switch is moved.
  3. Nikon Coolpix P530 Battery Replacement: passo 3, imagem 1 %32 Nikon Coolpix P530 Battery Replacement: passo 3, imagem 2 %32 Nikon Coolpix P530 Battery Replacement: passo 3, imagem 3 %32
    • Depress the yellow spring loaded tab holding the battery in place using your fingertip or plastic opening tools.
    • After the yellow tab is depressed, the battery should partially eject from the camera.
  4. Nikon Coolpix P530 Battery Replacement: passo 4, imagem 1 %32 Nikon Coolpix P530 Battery Replacement: passo 4, imagem 2 %32
    • Gently remove the battery from the chamber.
Conclusão
3 outras pessoas executaram este guia.
3 comentários
Thanks. Just checking the camera issues.
Suzanne von Leuschner - Responder
I can’t get the battery out of my camera. I've had the camera for 5 years with no previous problems. Any suggestions?
Bonnie Laub - Responder
top of the battery gets very hot when inserted .Is this normal?
Lowell Schiller - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 33
Duração total: 3,720
