Ir para o conteúdo principal
Nikon Coolpix P510 Motherboard Replacement
O que você precisa
  1. Nikon Coolpix P510 Motherboard Replacement, Battery Removal: passo 1, imagem 1 %32
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Motherboard Replacement: passo 2, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 2, imagem 2 %32
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
  3. Nikon Coolpix P510 Motherboard Replacement, Lens Assembly: passo 3, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement, Lens Assembly: passo 3, imagem 2 %32
    • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
    • On the thumb grip, remove the one 4mm PH00 Philips screw.
  4. Nikon Coolpix P510 Motherboard Replacement: passo 4, imagem 1 %32
    • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
    • One of the screws are under the HDMI and A/V Out cover.
  5. Nikon Coolpix P510 Motherboard Replacement: passo 5, imagem 1 %32
    • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
  6. Nikon Coolpix P510 Motherboard Replacement: passo 6, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 6, imagem 2 %32 Nikon Coolpix P510 Motherboard Replacement: passo 6, imagem 3 %32
    • Open the flash and use a plastic opening tool to pop the tab under it as shown.
    • Now pull the casing apart.
    • The tripod attachment may fall out on its own, or you will need to pull it out.
  7. Nikon Coolpix P510 Motherboard Replacement: passo 7, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 7, imagem 2 %32
    • Unplug the two ribbon cables to completely detach the back.
  8. Nikon Coolpix P510 Motherboard Replacement: passo 8, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 8, imagem 2 %32 Nikon Coolpix P510 Motherboard Replacement: passo 8, imagem 3 %32
    • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
    • Remove one 5mm PH00 Philips screw
    • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
    • With all the screws out, the metal plate should simply lift off.
  9. Nikon Coolpix P510 Motherboard Replacement: passo 9, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 9, imagem 2 %32
    • With the metal plate off, unplug this ribbon cable from the motherboard.
    • To remove the flat-topped connector, you simply lift it up to unplug it.
  10. Nikon Coolpix P510 Motherboard Replacement: passo 10, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 10, imagem 2 %32 Nikon Coolpix P510 Motherboard Replacement: passo 10, imagem 3 %32
    • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
  11. Nikon Coolpix P510 Motherboard Replacement: passo 11, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 11, imagem 2 %32
    • With the support screws out, you can simply slide the assembly out of the casing.
  12. Nikon Coolpix P510 Motherboard Replacement: passo 12, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 12, imagem 2 %32 Nikon Coolpix P510 Motherboard Replacement: passo 12, imagem 3 %32
    • If you are moving on to take the lens casing off, you do not need to do this step.
    • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
  13. Nikon Coolpix P510 Motherboard Replacement, Motherboard: passo 13, imagem 1 %32
    • Looking from the top of the camera, remove the 3mm PH00 Philips screw.
  14. Nikon Coolpix P510 Motherboard Replacement: passo 14, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 14, imagem 2 %32
    • Now grab the top panel of the thumb grip and pop it off.
  15. Nikon Coolpix P510 Motherboard Replacement: passo 15, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 15, imagem 2 %32
    • Now looking at the motherboard, unplug all four ribbon cables on it.
  16. Nikon Coolpix P510 Motherboard Replacement: passo 16, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 16, imagem 2 %32
    • There are four wires that need to unsoldered.
    • There are also three post that need to be unsoldered.
  17. Nikon Coolpix P510 Motherboard Replacement: passo 17, imagem 1 %32 Nikon Coolpix P510 Motherboard Replacement: passo 17, imagem 2 %32
    • before you can pull the board off, there is a tab that must be pushed back.
Conclusão
14 outras pessoas executaram este guia.
Brian Hulsey
Membro desde: 03/31/15
1.461 Reputação
Autoria de 6 guias
Equipe
Colorado Springs, Team 2-2, Panko Spring 2015 Membro de Colorado Springs, Team 2-2, Panko Spring 2015
UCCS-PANKO-S15S2G2
Membros da 3
Autoria de 12 guias
4 comentários
This is a wonderful presentation! My P510 got in saltwater; worked erratically; I disassembled and cleaned with alcohol and blew out sand and dried and reassembled and it worked! The copper thingy in pic 17B was left over. I mostly disassembled and reassembled and again, it worked! I found the dial on the back upper right was catchy so I partly disassembled again to blow out that dial. After assembly, the dial was free, but it would not power on! I’ve checked all my cable connections and still can’t get it to power on. Anybody have something for me to check? This presentation is still wonderful.
Dave Dbarc - Responder
Excellent guide - it gave me the courage and knowledge to partially strip my P510 and sort out an intermittent shutter release. Thank you!
mikecdraper - Responder
not worth a bother. motherboard costs as much as a camera itself. many have the issue with motherboard, so as far as I am concerned, I have no trust in any Nikon product
Milo Madacky - Responder
my advice: if you have one still functioning, ge rid of it asap. no spare parts from Nikon and on eBay and other outlets, can not get it cheaper than $150 a piece. Always respected Nikon but since I got dissapinted with this one, no Nikon for me
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 51
Duração total: 10,924
