Ir para o conteúdo principal
Nikon Coolpix P510 Battery Removal Replacement
O que você precisa
  1. Nikon Coolpix P510 Battery Removal Replacement, Battery Removal: passo 1, imagem 1 %32
    • Flip the camera over and push the tab on the battery cover to open the battery compartment.
  2. Nikon Coolpix P510 Battery Removal Replacement: passo 2, imagem 1 %32 Nikon Coolpix P510 Battery Removal Replacement: passo 2, imagem 2 %32
    • Push the little yellow tab to allow the battery to slide out.
    • With the tab pushed out, pull the battery out.
Conclusão
Brian Hulsey
Membro desde: 03/31/15
1.461 Reputação
Autoria de 6 guias
Equipe
Colorado Springs, Team 2-2, Panko Spring 2015 Membro de Colorado Springs, Team 2-2, Panko Spring 2015
UCCS-PANKO-S15S2G2
Membros da 3
Autoria de 12 guias
3 comentários
Even a 3 grader can figure this out. My problem is that I do this and the battery doesn't come up. It's stuck. What should I do???
victoria - Responder
Victoria, has had that problem too. In my case the battery was bloated. I had to wiggle it out with a butter knife until I could get a grip on it. I had to replace the battery.
david murray - Responder
Thank you so much for this information. I used a metal nail file and small pliers. It worked and the battery was swollen
klrider1961 -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 29
Duração total: 4,172
