Ir para o conteúdo principal
Nikon Coolpix P4 LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix P4 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Flip the camera upside down (have the side with the buttons facing away from you)
    • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
  2. Nikon Coolpix P4 LCD Screen Replacement: passo 2, imagem 1 %32
    • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
    • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
    • Once this slot is open, you can place the new battery inside.
    • Make sure to close the orange tab to secure it in place!
  3. Nikon Coolpix P4 LCD Screen Replacement, LCD Screen: passo 3, imagem 1 %32
    • Remove the four 2.2 mm screws located on the bottom of the camera.
  4. Nikon Coolpix P4 LCD Screen Replacement: passo 4, imagem 1 %32 Nikon Coolpix P4 LCD Screen Replacement: passo 4, imagem 2 %32
    • Remove the two 2.9 mm screws from the side panel.
    • Remove the side panel.
  5. Nikon Coolpix P4 LCD Screen Replacement: passo 5, imagem 1 %32 Nikon Coolpix P4 LCD Screen Replacement: passo 5, imagem 2 %32 Nikon Coolpix P4 LCD Screen Replacement: passo 5, imagem 3 %32
    • Remove the two 5 mm screws from the right side panel.
    • Remove the panel from the right side.
    • Remove the single 2.1 mm screw set underneath the panel.
  6. Nikon Coolpix P4 LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove the two 4.8 mm screws attaching the back panel to the body on the left side.
  7. Nikon Coolpix P4 LCD Screen Replacement: passo 7, imagem 1 %32
    • Gently pull off the back cover.
  8. Nikon Coolpix P4 LCD Screen Replacement: passo 8, imagem 1 %32 Nikon Coolpix P4 LCD Screen Replacement: passo 8, imagem 2 %32
    • Remove the three 4.8 mm screws from the A/V out tab on the left side.
    • Remove the tab.
  9. Nikon Coolpix P4 LCD Screen Replacement: passo 9, imagem 1 %32
    • Remove the two 4.6 mm screws attaching the front panel to the body on the left side.
  10. Nikon Coolpix P4 LCD Screen Replacement: passo 10, imagem 1 %32
    • Flip up the front panel.
    • Potential for device damage. There should be wires still attaching the panel to the body. DO NOT TRY TO PULL OFF COMPLETELY.
  11. Nikon Coolpix P4 LCD Screen Replacement: passo 11, imagem 1 %32
    • Remove the 2.2 mm screw.
    • Remove the 2.9 mm screw.
    • Remove the 2.1 mm screw.
  12. Nikon Coolpix P4 LCD Screen Replacement: passo 12, imagem 1 %32
    • Carefully pull the orange LCD connector up and out of the port.
    • Be careful to pull vertically while pushing the black tab upwards
  13. Nikon Coolpix P4 LCD Screen Replacement: passo 13, imagem 1 %32
    • Remove the 3.1 mm screw below the LCD.
  14. Nikon Coolpix P4 LCD Screen Replacement: passo 14, imagem 1 %32
    • Carefully pull out the plug connecting the LCD to the motherboard.
  15. Nikon Coolpix P4 LCD Screen Replacement: passo 15, imagem 1 %32
    • Remove the LCD from the camera body.
Conclusão
Luke Baumann
Membro desde: 04/13/11
128 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 8-5, Regan Spring 2011 Membro de Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
4 Membros
Autoria de 10 guias
1Comentário do guia
Where did you get the screen?
jharrison - Responder
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 3,361
