Ir para o conteúdo principal
Nikon Coolpix P4 Battery Replacement
  1. Nikon Coolpix P4 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Flip the camera upside down (have the side with the buttons facing away from you)
    • Look for the side with the triangle icon with three lines in it, this is the battery door. Add pressure and slide this door slightly until it clicks and pops open.
  2. Nikon Coolpix P4 Battery Replacement: passo 2, imagem 1 %32
    • Once the door clicks, you can open it to reveal the slots holding the memory card and the battery.
    • Focusing on the larger slot, this holds the battery. Push the orange tab away from the slot, this will eject the old battery if one was previously inside.
    • Once this slot is open, you can place the new battery inside.
    • Make sure to close the orange tab to secure it in place!
Conclusão
Luke Baumann
Membro desde: 04/13/11
128 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 8-5, Regan Spring 2011 Membro de Cal Poly, Team 8-5, Regan Spring 2011
CPSU-REGAN-S11S8G5
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 2,450
