Ir para o conteúdo principal
Nikon Coolpix P100 Display Screen Replacement
O que você precisa
  1. Nikon Coolpix P100 Display Screen Replacement, Display Screen: passo 1, imagem 1 %32 Nikon Coolpix P100 Display Screen Replacement, Display Screen: passo 1, imagem 2 %32 Nikon Coolpix P100 Display Screen Replacement, Display Screen: passo 1, imagem 3 %32
    • Flip the camera upside down so that the side with the serial number is face up.
    • Pull back the display panel. Orient the panel so that you are able to view the back of it.
  2. Nikon Coolpix P100 Display Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix P100 Display Screen Replacement: passo 2, imagem 2 %32
    • Remove the two screws closest to the piece connecting the panel to the camera with a Phillips #1 screwdriver.
  3. Nikon Coolpix P100 Display Screen Replacement: passo 3, imagem 1 %32
    • Remove the cover that was unscrewed in the last step.
  4. Nikon Coolpix P100 Display Screen Replacement: passo 4, imagem 1 %32
    • Remove the remaining four screws on the outermost corners of the panel using a Phillips #1 screwdriver.
  5. Nikon Coolpix P100 Display Screen Replacement: passo 5, imagem 1 %32 Nikon Coolpix P100 Display Screen Replacement: passo 5, imagem 2 %32 Nikon Coolpix P100 Display Screen Replacement: passo 5, imagem 3 %32
    • Use a plastic opening tool to pry open the back panel of the display screen.
  6. Nikon Coolpix P100 Display Screen Replacement: passo 6, imagem 1 %32 Nikon Coolpix P100 Display Screen Replacement: passo 6, imagem 2 %32 Nikon Coolpix P100 Display Screen Replacement: passo 6, imagem 3 %32
    • Carefully unhook the ribbon that attaches the panel to the camera.
    • Remove the top black panel cover.
  7. Nikon Coolpix P100 Display Screen Replacement: passo 7, imagem 1 %32
    • Remove the two screws on the panel that are closest to the ribbon cable using a Phillips #1 screwdriver.
  8. Nikon Coolpix P100 Display Screen Replacement: passo 8, imagem 1 %32
    • Remove the other two screws on the opposite side of the panel using a Phillips #1 screwdriver.
  9. Nikon Coolpix P100 Display Screen Replacement: passo 9, imagem 1 %32 Nikon Coolpix P100 Display Screen Replacement: passo 9, imagem 2 %32
    • Separate the metal portion of the screen from the plastic portion.
  10. Nikon Coolpix P100 Display Screen Replacement: passo 10, imagem 1 %32 Nikon Coolpix P100 Display Screen Replacement: passo 10, imagem 2 %32
    • Carefully remove the ribbon connector cable from the metal portion of the display.
    • Remove the display from the rest of the device.
Conclusão
5 outras pessoas executaram este guia.
Rikki Brown
Membro desde: 01/09/15
267 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Tanski Winter 2015 Membro de USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
Membros da 3
Autoria de 8 guias
3 comentários
This guide help me to change my screen on Nikon P100 with out to much trouble, however I found step 7 unnecessary.
David Fyock - Responder
Hello, I've a problem during the re-mount of the display. Someone can help me? Thanks in advance! Mark
cwmark56 - Responder
I can't reconnect the connector on the step 10. Can you help me?
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 44
Duração total: 2,730
