Ir para o conteúdo principal
Nikon Coolpix P100 Back Buttons Replacement
O que você precisa
  1. Nikon Coolpix P100 Back Buttons Replacement, Back Buttons: passo 1, imagem 1 %32
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100 Back Buttons Replacement: passo 2, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 2, imagem 2 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 2, imagem 3 %32
    • On the left side of the camera, remove two screws using a Phillips #00 screwdriver.
  3. Nikon Coolpix P100 Back Buttons Replacement: passo 3, imagem 1 %32
    • On the right side of the camera, remove the first visible screw.
  4. Nikon Coolpix P100 Back Buttons Replacement: passo 4, imagem 1 %32
    • Lift the HDMI and A/V OUT cover to access the hidden screw.
  5. Nikon Coolpix P100 Back Buttons Replacement: passo 5, imagem 1 %32
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100 Back Buttons Replacement: passo 6, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 6, imagem 2 %32
    • Remove the two screws hidden underneath the display panel.
  7. Nikon Coolpix P100 Back Buttons Replacement: passo 7, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 7, imagem 2 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 7, imagem 3 %32
    • Use a plastic opening tool to gently loosen up the sides of the camera.
  8. Nikon Coolpix P100 Back Buttons Replacement: passo 8, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 8, imagem 2 %32
    • Carefully open the camera.
    • There are two ribbon cables when opening the camera. Make sure to properly detach them before proceeding.
  9. Nikon Coolpix P100 Back Buttons Replacement: passo 9, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 9, imagem 2 %32
    • This is the cover that houses the back buttons of the camera. Turn it around.
  10. Nikon Coolpix P100 Back Buttons Replacement: passo 10, imagem 1 %32
    • Remove the six indicated screws.
  11. Nikon Coolpix P100 Back Buttons Replacement: passo 11, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 11, imagem 2 %32
    • Use a plastic opening tool to lift the metal plate and set it aside.
  12. Nikon Coolpix P100 Back Buttons Replacement: passo 12, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 12, imagem 2 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 12, imagem 3 %32
    • Turn the cover around and push against the buttons.
  13. Nikon Coolpix P100 Back Buttons Replacement: passo 13, imagem 1 %32
    • Now you have partial access to one set of buttons.
  14. Nikon Coolpix P100 Back Buttons Replacement: passo 14, imagem 1 %32
    • Find the last set of removal buttons on the bottom left.
  15. Nikon Coolpix P100 Back Buttons Replacement: passo 15, imagem 1 %32
    • Remove the screw.
  16. Nikon Coolpix P100 Back Buttons Replacement: passo 16, imagem 1 %32 Nikon Coolpix P100 Back Buttons Replacement: passo 16, imagem 2 %32
    • Use a plastic opening tool to remove the button.
Conclusão
Nghiem Ngo
Membro desde: 01/15/15
330 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Tanski Winter 2015 Membro de USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
Membros da 3
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 14
Duração total: 817
