Ir para o conteúdo principal
Nikon Coolpix P100 Motherboard Access
O que você precisa
  1. Nikon Coolpix P100  Motherboard Access, Nikon Coolpix P100  Motherboard Access: passo 1, imagem 1 %32
    • Turn the front of the camera toward you.
  2. Nikon Coolpix P100  Motherboard Access: passo 2, imagem 1 %32 Nikon Coolpix P100  Motherboard Access: passo 2, imagem 2 %32 Nikon Coolpix P100  Motherboard Access: passo 2, imagem 3 %32
    • On the left side of the camera, use a Phillips #00 Precision Screwdriver to remove the two marked screws.
  3. Nikon Coolpix P100  Motherboard Access: passo 3, imagem 1 %32
    • On the right side of the camera, remove the first visible screw above the HDMI and A/V OUT cover.
  4. Nikon Coolpix P100  Motherboard Access: passo 4, imagem 1 %32
    • Lift the HDMI and A/V OUT cover to access the hidden screw between the two ports.
    • Remove the screw
  5. Nikon Coolpix P100  Motherboard Access: passo 5, imagem 1 %32
    • Flip the camera upside down and remove the seven marked screws.
  6. Nikon Coolpix P100  Motherboard Access: passo 6, imagem 1 %32 Nikon Coolpix P100  Motherboard Access: passo 6, imagem 2 %32
    • Turn the back of the camera toward you.
    • Lift the display panel and remove the two marked screws
  7. Nikon Coolpix P100  Motherboard Access: passo 7, imagem 1 %32 Nikon Coolpix P100  Motherboard Access: passo 7, imagem 2 %32 Nikon Coolpix P100  Motherboard Access: passo 7, imagem 3 %32
    • Use a plastic iFixit opening tool to gently loosen the top and sides of the camera.
  8. Nikon Coolpix P100  Motherboard Access: passo 8, imagem 1 %32
    • Before fully opening the camera, identify the two marked ribbon cables
    • Properly detach the ribbons before proceeding
  9. Nikon Coolpix P100  Motherboard Access: passo 9, imagem 1 %32
    • Carefully open the camera.
    • Now you have partial access to the camera's motherboard.
  10. Nikon Coolpix P100  Motherboard Access: passo 10, imagem 1 %32
    • Remove the five indicated screws that are attached to the metal plate.
  11. Nikon Coolpix P100  Motherboard Access: passo 11, imagem 1 %32
    • Remove the hidden top screw that is attached to the metal plate.
  12. Nikon Coolpix P100  Motherboard Access: passo 12, imagem 1 %32
    • Use a plastic iFixit opening tool to carefully loosen the metal plate.
    • Remove the metal plate to access the camera's motherboard.
  13. Nikon Coolpix P100  Motherboard Access: passo 13, imagem 1 %32
    • Now you have access to the camera's motherboard
Conclusão
Rikki Brown
Membro desde: 01/09/15
267 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 1-1, Tanski Winter 2015 Membro de USF Tampa, Team 1-1, Tanski Winter 2015
USFT-TANSKI-W15S1G1
Membros da 3
Autoria de 8 guias
Um comentário
y como cambia el lente si se atasca
djalfonsodaza - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 23
Duração total: 2,455
