Ir para o conteúdo principal
Nikon Coolpix L840 Lanyard Ring Replacement
O que você precisa
  1. Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: passo 1, imagem 1 %32 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: passo 1, imagem 2 %32 Nikon Coolpix L840 Lanyard Ring Replacement, Motherboard: passo 1, imagem 3 %32
    • Unscrew all eight black, 4mm screws with a Philips 000. (The top-most screw shown in the third image can be accessed by lifting the cover flap off.)
  2. Nikon Coolpix L840 Lanyard Ring Replacement: passo 2, imagem 1 %32
    • Pry case open with a metal spludger by slipping the spludger between the back and front case of the camera and wiggling the spludger forwards and backwards.
    • Be careful not to damage the inner components of the camera when slipping the spludger into the camera.
  3. Nikon Coolpix L840 Lanyard Ring Replacement: passo 3, imagem 1 %32 Nikon Coolpix L840 Lanyard Ring Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Carefully unhook the silver strip with tweezers. Get a grasp of the sides of the silver strip with the tweezers, and pull upwards and out.
    • The strip may also be identified by its blue tip, which becomes more visible once pulled out.
  4. Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: passo 4, imagem 1 %32 Nikon Coolpix L840 Lanyard Ring Replacement, Lanyard Ring: passo 4, imagem 2 %32
    • Identify lanyard ring.
    • Unscrew the 4 mm black screw with a Philips 000.
  5. Nikon Coolpix L840 Lanyard Ring Replacement: passo 5, imagem 1 %32 Nikon Coolpix L840 Lanyard Ring Replacement: passo 5, imagem 2 %32
    • Insert a metal spludger (or another sturdy tool with a thin tip) into the hole of the lanyard ring and lift the ring upwards and out of the camera.
Conclusão
Uma outra pessoa concluiu este guia.
Abraham Lozano
Membro desde: 04/11/16
595 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 1-11, Maness Spring 2016 Membro de Cal Poly, Team 1-11, Maness Spring 2016
CPSU-MANESS-S16S1G11
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 657
