Ir para o conteúdo principal
Nikon Coolpix L820 Shutter Button Replacement
O que você precisa
  1. Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: passo 1, imagem 1 %32 Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: passo 1, imagem 2 %32 Nikon Coolpix L820 Shutter Button Replacement, Settings Buttons: passo 1, imagem 3 %32
    • Remove the battery before beginning.
    • Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
  2. Nikon Coolpix L820 Shutter Button Replacement: passo 2, imagem 1 %32 Nikon Coolpix L820 Shutter Button Replacement: passo 2, imagem 2 %32
    • Remove the front top Phillips screw with the screwdriver.
    • Open the empty battery slot on the bottom of the camera, revealing four additional screws.
    • Unscrew the four Phillips screws with the screwdriver.
  3. Nikon Coolpix L820 Shutter Button Replacement: passo 3, imagem 1 %32 Nikon Coolpix L820 Shutter Button Replacement: passo 3, imagem 2 %32 Nikon Coolpix L820 Shutter Button Replacement: passo 3, imagem 3 %32
    • Using the spudger, move around the casing, carefully separating the rear housing from the camera assembly.
    • Be sure to only apply pressure to the casing panels and not the sensitive internal electronics.
    • Once the rear housing is separated, the settings buttons will be accessible for replacement.
  4. Nikon Coolpix L820 Shutter Button Replacement, LCD screen: passo 4, imagem 1 %32 Nikon Coolpix L820 Shutter Button Replacement, LCD screen: passo 4, imagem 2 %32 Nikon Coolpix L820 Shutter Button Replacement, LCD screen: passo 4, imagem 3 %32
    • Remove the front casing to expose the LCD screen and wires.
    • Do not damage the exposed wires.
  5. Nikon Coolpix L820 Shutter Button Replacement: passo 5, imagem 1 %32 Nikon Coolpix L820 Shutter Button Replacement: passo 5, imagem 2 %32 Nikon Coolpix L820 Shutter Button Replacement: passo 5, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using the tweezers, lift the hinges connecting the two ribbon wires to the camera.
  6. Nikon Coolpix L820 Shutter Button Replacement: passo 6, imagem 1 %32 Nikon Coolpix L820 Shutter Button Replacement: passo 6, imagem 2 %32
    • Once the flexible ribbon wires are disconnected, remove the LCD screen.
  7. Nikon Coolpix L820 Shutter Button Replacement, Shutter Button: passo 7, imagem 1 %32
    • Remove these five Phillips screws, from the back of the camera, with the Phillips screwdriver.
  8. Nikon Coolpix L820 Shutter Button Replacement: passo 8, imagem 1 %32
    • Using the pointed edge of the spudger, lift the hinge that secures this flex circuit. This will unfasten the flexible ribbon wire.
  9. Nikon Coolpix L820 Shutter Button Replacement: passo 9, imagem 1 %32
    • Remove the panel containing the shutter and zoom slider, by lifting it up.
  10. Nikon Coolpix L820 Shutter Button Replacement: passo 10, imagem 1 %32
    Comprar
    • Remove the metal cover using tweezers to allow access to the shutter button.
    • Replace shutter button.
Conclusão
Jimmy Kendall
Membro desde: 03/23/15
137 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 1-4, Miles Spring 2015 Membro de UMass Dartmouth, Team 1-4, Miles Spring 2015
UMASSD-MILES-S15S1G4
Membros da 3
Autoria de 10 guias
3 comentários
Muy bueno pero falta documentar 3 tornillos.
1. En el paso 1, en la tercera foto debajo del sticker del código de barras.
2. En el paso 2, justo en el fondo del compartimento de una de las baterías (la del extremo). Incluso se alcanza a apreciar en la foto.
3. En el paso 8, en esa misma pieza de metal a un lado está el otro tornillo.
cyrez_1509 - Responder
My shutter button still works but doesn’t give feedback. It’s hard to tell when I’ve taken a picture because it doesn’t “click.” I’m wondering if that’s something that can be fixed, but I can’t tell if the mechanism for that feedback is in the mechanical portion above (and maybe a piece of metal broke) or built into the switch soldered on the circuit board.
JM Palacios - Responder
Dove si può acquistare il bottone a buon prezzo? grazie
Where can you buy the button at a good price? Thank you
Massimino Diquarto - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 3,249
