Introdução
The LCD screen is an essential component of a camera. If the LCD screen stops working, the camera can no longer be used. In this repair guide, you will learn how to replace the LCD screen on the Nikon Coolpix L820 camera.
O que você precisa
Use a Phillips #0 screwdriver to remove the screws on the front casing. There are ten screws, three on the left side, two on the bottom, and one on the right side of the camera.
