Ir para o conteúdo principal
Nikon Coolpix L810 Flash Replacement
O que você precisa
  1. Nikon Coolpix L810 Flash Replacement, Flash: passo 1, imagem 1 %32
    • Remove two 5 mm Phillips #000 screws below the flash component.
    • In order to complete this step the flash must be open. To open the flash press the button located above the lens on the leftward side of the camera.
  2. Nikon Coolpix L810 Flash Replacement: passo 2, imagem 1 %32
    • Use blue plastic opening tool to pry open the casing for the flash.
  3. Nikon Coolpix L810 Flash Replacement: passo 3, imagem 1 %32
    • Remove the plastic casing surrounding the flash.
  4. Nikon Coolpix L810 Flash Replacement: passo 4, imagem 1 %32 Nikon Coolpix L810 Flash Replacement: passo 4, imagem 2 %32
    • Pull the wires connecting the flash out of the camera.
  5. Nikon Coolpix L810 Flash Replacement: passo 5, imagem 1 %32 Nikon Coolpix L810 Flash Replacement: passo 5, imagem 2 %32 Nikon Coolpix L810 Flash Replacement: passo 5, imagem 3 %32
    • Unsolder the wires that connect the flash component.
Conclusão
Emilio Mena
Membro desde: 01/14/15
776 Reputação
Autoria de 4 guias
Equipe
UW Tacoma, Team 3-1, Rose Winter 2015 Membro de UW Tacoma, Team 3-1, Rose Winter 2015
UWT-ROSE-W15S3G1
Membros da 4
Autoria de 8 guias
4 comentários
It's not a comment, but where did you obtain the replacement flashbulb?
hgdddee - Responder
the heading says no parts required. but I think i need a new flashbulb? any idea what the type is or where to buy it ?
wildstreaksavannahs - Responder
I can't get into bulb
Szabolcs Demeter - Responder
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a> n advmd vdsm vs ds m
nirik - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Duração total: 2,209
