Introdução
This is a guide to remove the power button. It is a simple task that can be done after removing the outer case of the camera.
O que você precisa
Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
Remove the panel containing the power and shutter button.
Conclusão
