Ir para o conteúdo principal
Nikon Coolpix L610 Plastic Cover Replacement
O que você precisa
  1. Nikon Coolpix L610 Plastic Cover Replacement, Plastic Cover: passo 1, imagem 1 %32 Nikon Coolpix L610 Plastic Cover Replacement, Plastic Cover: passo 1, imagem 2 %32
    • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
    Pergunte ao FixBot
  2. Nikon Coolpix L610 Plastic Cover Replacement: passo 2, imagem 1 %32
    • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
    • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
    Pergunte ao FixBot
  3. Nikon Coolpix L610 Plastic Cover Replacement: passo 3, imagem 1 %32
    • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
    • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
    Pergunte ao FixBot
  4. Nikon Coolpix L610 Plastic Cover Replacement: passo 4, imagem 1 %32 Nikon Coolpix L610 Plastic Cover Replacement: passo 4, imagem 2 %32 Nikon Coolpix L610 Plastic Cover Replacement: passo 4, imagem 3 %32
    • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
    Pergunte ao FixBot
Conclusão
3 outras pessoas executaram este guia.
Jeremy
Membro desde: 01/21/15
1.099 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-4, Brown Winter 2015 Membro de USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Membros
Autoria de 12 guias
1Comentário do guia
getting the front and back covers off is less than half the procedure. now you have to get at the pin that that holds the battery cover in place. next the battery cover has a metal contact strip with 2 more screws. but behind that there is a release button and a very small spring that has to be transfered to the new battery cover. then the pin that holds cover needs to put in place. after cleaning the screens. then put on the covers front and back. carefull to use the correct screws in hte right holes. suggest doing work over a white piece of paper. having a well lite area. using a magnofy glass is helpful. als having a magnet and tweezers availble. 1st time be prepared to take well over an hour.
CHRIS MITCHELL - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 52
Ao todo: 2,415
