Ir para o conteúdo principal
Nikon Coolpix L610 LCD Screen Replacement
O que você precisa
    1. Nikon Coolpix L610 LCD Screen Replacement, Plastic Cover: passo 1, imagem 1 %32 Nikon Coolpix L610 LCD Screen Replacement, Plastic Cover: passo 1, imagem 2 %32
      • Remove the four (3.20 mm) Phillips #00 screws at the bottom of the device.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L610 LCD Screen Replacement: passo 2, imagem 1 %32
      • Remove the top (4.10 mm) Phillips #00 screw adjacent to the battery compartment.
      • Remove the bottom (3.20 mm) Phillips #00 screw adjacent to the battery compartment.
      Pergunte ao FixBot
      Comentar
    3. Nikon Coolpix L610 LCD Screen Replacement: passo 3, imagem 1 %32
      • Remove the top (4.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite the battery side.
      • Remove the lower (3.20 mm) Phillips #00 screw adjacent to the mic side of the camera and opposite of the battery side.
      Pergunte ao FixBot
      Comentar
    4. Nikon Coolpix L610 LCD Screen Replacement: passo 4, imagem 1 %32 Nikon Coolpix L610 LCD Screen Replacement: passo 4, imagem 2 %32 Nikon Coolpix L610 LCD Screen Replacement: passo 4, imagem 3 %32
      • Separate the case using the plastic prying tool. This can be done by placing the tool in the position that is shown and in the position on the left side of the camera.
      Pergunte ao FixBot
      Comentar
    1. Nikon Coolpix L610 LCD Screen Replacement, Removing the screen: passo 5, imagem 1 %32
      • Using a prying tool, carefully lift up the LCD screen but do NOT pull it off.
      Pergunte ao FixBot
      Comentar
    2. Nikon Coolpix L610 LCD Screen Replacement, Removing the LCD Screen Ribbon: passo 6, imagem 1 %32 Nikon Coolpix L610 LCD Screen Replacement, Removing the LCD Screen Ribbon: passo 6, imagem 2 %32
      • While the LCD screen is loose and unattached, there is a latch that is holding the ribbon in place. Slide the latch down and pull the ribbon out.
      Pergunte ao FixBot
      Comentar
Conclusão
Jeremy
Membro desde: 01/21/15
1.099 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 9-4, Brown Winter 2015 Membro de USF Tampa, Team 9-4, Brown Winter 2015
USFT-BROWN-W15S9G4
4 Membros
Autoria de 36 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 12
Últimos 30 dias: 45
Ao todo: 1,471
