Ir para o conteúdo principal
Nikon Coolpix L340 Memory Card Replacement
  1. Nikon Coolpix L340 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32 Nikon Coolpix L340 Memory Card Replacement, Memory Card: passo 1, imagem 2 %32
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera.
    • If the camera lens is pointing towards you, there should be a small lever on the right hand side.
    • Take this lever and push it away from your body, while simultaneously pulling upwards.
  2. Nikon Coolpix L340 Memory Card Replacement: passo 2, imagem 1 %32
    • Gently press down on the memory card until you hear a click, then release the pressure to eject the card and slowly pull it upwards out of the slot.
Conclusão
Kelly Kryzak
Membro desde: 04/12/16
140 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 3-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 1,526
