Ir para o conteúdo principal
Nikon Coolpix L340 Battery Replacement
  1. Nikon Coolpix L340 Battery Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix L340 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Turn the camera so that the flash is facing downward- you are now looking at the bottom of the camera
    • If the camera lens its pointing towards you, there should be a small lever on the right hand side
    • Take this lever and push it away from your body, while simultaneously pulling upwards
  2. Nikon Coolpix L340 Battery Replacement: passo 2, imagem 1 %32 Nikon Coolpix L340 Battery Replacement: passo 2, imagem 2 %32
    • Once you have pulled up, four batteries will appear underneith
    • Note how there are two batteries facing upwards (circled in red)
    • and two batteries facing downwards (circled in orange)
    • When the new batteries are placed back in the camera, they should be put back in this same orientation
  3. Nikon Coolpix L340 Battery Replacement: passo 3, imagem 1 %32
    • Take out each of the batteries
  4. Nikon Coolpix L340 Battery Replacement: passo 4, imagem 1 %32
    • When all of the batteries have been removed you should see four places for four new batteries to be inserted
Conclusão
Nikki Butts
Membro desde: 03/04/16
179 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 3-3, Bhusal Spring 2016 Membro de UMass Dartmouth, Team 3-3, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G3
Membros da 4
Autoria de 8 guias
4 comentários
Hi, I just replaced my Nikon Coolpix L340's batteries with new AAs and have followed all steps correctly but my camera is still saying 'battery exhausted' when I try turning it back on. Any ideas why it's not working?
Thank you!
Mia - Responder
The negative terminal must be raised like the Duracell Ultra. The Energizer MAX and other AAs have a FLAT negative terminal. The manual warns against them.
thestevelink -
No lever, only recessed button
ccpotts47 - Responder
thestevelink - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 20
Últimos 30 dias: 100
Duração total: 9,794
