Ir para o conteúdo principal
Nikon Coolpix L32 Memory Card Replacement
  1. Nikon Coolpix L32 Memory Card Replacement, Memory Card: passo 1, imagem 1 %32
    • Slide the lock button on the battery compartment away from you while sliding the battery compartment door to the right to open the battery compartment door.
  2. Nikon Coolpix L32 Memory Card Replacement: passo 2, imagem 1 %32
    • Push in the memory card until you hear a “click” noise, remove the old one and install the new one
    • When the new memory card is being installed make sure to hear a "click" noise once again
Conclusão
Weston Phillips
Membro desde: 09/20/16
104 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2016 Membro de USF Tampa, Team 2-4, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G4
Membros da 4
Autoria de 10 guias
Um comentário
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 591
