Ir para o conteúdo principal
Nikon Coolpix L27 Screen Replacement
O que você precisa
  1. Nikon Coolpix L27 Screen Replacement, Screen: passo 1, imagem 1 %32 Nikon Coolpix L27 Screen Replacement, Screen: passo 1, imagem 2 %32 Nikon Coolpix L27 Screen Replacement, Screen: passo 1, imagem 3 %32
    • Undo the latch at the bottom of the camera by pushing it to the side
    • Remove the batteries (and memory card if applicable)
  2. Nikon Coolpix L27 Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix L27 Screen Replacement: passo 2, imagem 2 %32
    • Remove the two 5 mm Phillips #000 screws from the left side.
  3. Nikon Coolpix L27 Screen Replacement: passo 3, imagem 1 %32 Nikon Coolpix L27 Screen Replacement: passo 3, imagem 2 %32 Nikon Coolpix L27 Screen Replacement: passo 3, imagem 3 %32
    • Lift the cover labeled "A/V OUT" to expose a hidden screw.
    • Remove two 5 mm Phillips #000 screws from the bottom of the camera.
  4. Nikon Coolpix L27 Screen Replacement: passo 4, imagem 1 %32 Nikon Coolpix L27 Screen Replacement: passo 4, imagem 2 %32
    • Remove the two 5 mm Phillips #000 screws from the right side of the camera.
  5. Nikon Coolpix L27 Screen Replacement: passo 5, imagem 1 %32 Nikon Coolpix L27 Screen Replacement: passo 5, imagem 2 %32 Nikon Coolpix L27 Screen Replacement: passo 5, imagem 3 %32
    • Carefully pry the back cover starting from the battery latch.
    • Once all sides are loose, lift the back cover up and off.
  6. Nikon Coolpix L27 Screen Replacement: passo 6, imagem 1 %32
    • Carefully lift the LCD screen up towards the bottom of the camera.
    • The LCD is connected to a cable so don't pull it out yet.
  7. Nikon Coolpix L27 Screen Replacement: passo 7, imagem 1 %32
    • Lightly push back the white switch holding in the screen cable
  8. Nikon Coolpix L27 Screen Replacement: passo 8, imagem 1 %32 Nikon Coolpix L27 Screen Replacement: passo 8, imagem 2 %32
    • Remove the cable from the camera.
    • Lift the screen out.
Conclusão
Vishalpreet Sandhu
Membro desde: 01/18/22
157 Reputação
Autoria de 1 guia
Equipe
Um comentário
would you know how to replace the little button battery just next to the screen, because the Lense is not retracting anymore?
Walter D. - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 25
Duração total: 464
