Ir para o conteúdo principal
Nikon Coolpix L18 LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix L18 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: passo 3, imagem 1 %32
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
    Be very careful not to touch the flash capacitor on far left when lifting the LCD!! It WILL shock you.
    Mark Fraylick - Responder
    Getting the LCD ribbon back "in" is my problem -- hints or suggestions?
    richardkujawa - Responder
    I can't get a feel for how the black clip holds the ribbon - insert the new one at an angle?
    I practiced a few times with the "bad screen" and managed to figure this out. Unfortunately I can't explain how I did it... if some other person can explain how to make the ribbon connection/clip re-install more predictable I think it'd help anyone else who tries the repair.
  6. Nikon Coolpix L18 LCD Screen Replacement: passo 6, imagem 1 %32
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
Conclusão
8 outras pessoas executaram este guia.
Nonny
Membro desde: 10/11/10
219 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-23, Regan Fall 2010 Membro de Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
Membros da 4
Autoria de 10 guias
4 comentários
Good work! Appreciate it.
Oasis World - Responder
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - Responder
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 7,058
