Ir para o conteúdo principal
Nikon Coolpix L18 LCD Screen Replacement
O que você precisa
  1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 LCD Screen Replacement: passo 2, imagem 1 %32 Nikon Coolpix L18 LCD Screen Replacement: passo 2, imagem 2 %32
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 LCD Screen Replacement: passo 3, imagem 1 %32
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 LCD Screen Replacement: passo 5, imagem 1 %32
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 LCD Screen Replacement: passo 6, imagem 1 %32
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
Conclusão
8 outras pessoas executaram este guia.
Nonny
Membro desde: 10/11/10
234 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-23, Regan Fall 2010 Membro de Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
4 Membros
Autoria de 10 guias
4Comentários do guia
Good work! Appreciate it.
Oasis World - Responder
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - Responder
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick -
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 42
Ao todo: 7,396
