Ir para o conteúdo principal
Nikon Coolpix L18 Front Cover Replacement
O que você precisa
  1. Nikon Coolpix L18 Front Cover Replacement, Back Cover: passo 1, imagem 1 %32
    • Remove the memory stick from the camera.
    • Remove the batteries from the camera.
  2. Nikon Coolpix L18 Front Cover Replacement: passo 2, imagem 1 %32 Nikon Coolpix L18 Front Cover Replacement: passo 2, imagem 2 %32
    • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
    • There is one screw hidden under the AV cover that also needs to be removed.
  3. Nikon Coolpix L18 Front Cover Replacement: passo 3, imagem 1 %32
    • Pry the back cover from the left side of the camera. Remove the cover gently.
  4. Nikon Coolpix L18 Front Cover Replacement, LCD Screen: passo 4, imagem 1 %32
    • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
    • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
  5. Nikon Coolpix L18 Front Cover Replacement: passo 5, imagem 1 %32
    • Remove the tape on the right side of the LCD screen.
    • Gently lift the LCD screen from its base.
    • Don't tug on the screen because it is still connected to the motherboard.
  6. Nikon Coolpix L18 Front Cover Replacement: passo 6, imagem 1 %32
    • Lift the black latch connecting the LCD ribbon to the motherboard.
    • Gently pull the LCD ribbon out.
  7. Nikon Coolpix L18 Front Cover Replacement, Front Cover: passo 7, imagem 1 %32
    • Pry back the front cover of the camera starting from the right side.
Conclusão
Uma outra pessoa concluiu este guia.
Andrea Govea
Membro desde: 10/11/10
360 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 9-23, Regan Fall 2010 Membro de Cal Poly, Team 9-23, Regan Fall 2010
CPSU-REGAN-F10S9G23
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 3,242
