Ir para o conteúdo principal
Nikon Coolpix E5700 Top Display Screen Replacement
O que você precisa
  1. Nikon Coolpix E5700 Top Display Screen Replacement, Battery: passo 1, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement, Battery: passo 1, imagem 2 %32
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Nikon Coolpix E5700 Top Display Screen Replacement: passo 2, imagem 1 %32
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
  3. Nikon Coolpix E5700 Top Display Screen Replacement, Back Panel: passo 3, imagem 1 %32
    • Turn to the bottom of the camera.
    • Remove the two Phillips screws located directly below the back monitor
  4. Nikon Coolpix E5700 Top Display Screen Replacement: passo 4, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 4, imagem 2 %32
    • Turn the camera to the side with the memory card slot and open the compartment for the CF card.
    • Remove the top two Phillips screws closest to the back panel.
  5. Nikon Coolpix E5700 Top Display Screen Replacement: passo 5, imagem 1 %32
    • Turn to the back of the camera.
    • Remove the top most Phillips screw on the back panel.
  6. Nikon Coolpix E5700 Top Display Screen Replacement: passo 6, imagem 1 %32
    • Turn to the last side of the back panel.
    • Remove the Phillips screw below the eyepiece.
    • Remove the Phillips screw located above the speaker.
  7. Nikon Coolpix E5700 Top Display Screen Replacement: passo 7, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 7, imagem 2 %32
    • Gently begin to remove the back panel.
    • Caution: There are two bundles of wires connecting the back panel to the camera. Be sure not to pull too hard and yank these out.
  8. Nikon Coolpix E5700 Top Display Screen Replacement: passo 8, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 8, imagem 2 %32
    • Now gently unplug the two wires at the bottom of the panel.
  9. Nikon Coolpix E5700 Top Display Screen Replacement, Top Cover: passo 9, imagem 1 %32
    • Finish pulling away the back panel.
    • Turn the camera to its non-grip side.
    • Remove the Phillips screw located above the strap holder.
  10. Nikon Coolpix E5700 Top Display Screen Replacement: passo 10, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 10, imagem 2 %32
    • Open the CF card slot.
    • Remove the Phillips screw near the top of the camera.
  11. Nikon Coolpix E5700 Top Display Screen Replacement: passo 11, imagem 1 %32
    • Turn to the front of the camera.
    • Lift up the corner of the grip pad nearest to the flash bulb.
    • Remove the Phillips screw underneath the grip pad.
  12. Nikon Coolpix E5700 Top Display Screen Replacement: passo 12, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 12, imagem 2 %32
    • Lift up the flash bulb container.
    • Remove the two Phillips screws located near the base of the section.
  13. Nikon Coolpix E5700 Top Display Screen Replacement: passo 13, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 13, imagem 2 %32
    • Open the battery compartment.
    • Remove the Phillips screw located at the bottom of the battery compartment.
  14. Nikon Coolpix E5700 Top Display Screen Replacement: passo 14, imagem 1 %32
    • Begin to lift the top cover from the rest of the camera.
    • Be careful when doing this because many wires are connecting the top piece to the camera. Pulling too hard may pull these wires out.
  15. Nikon Coolpix E5700 Top Display Screen Replacement: passo 15, imagem 1 %32
    • In order to pull the top panel without removing the flash unit. You must remove the flash top cover, taking away the screw under the bulb (see image). then gently remove the plastic top cover. IMPORTANT: discharge the condenser as soon as possible (the flash wires are now exposed, and dangerous ).
  16. Nikon Coolpix E5700 Top Display Screen Replacement: passo 16, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 16, imagem 2 %32
    • Unplug the orange ribbon wire from the back of the camera.
    • Unplug the two blue ribbon wires from the back of the camera.
  17. Nikon Coolpix E5700 Top Display Screen Replacement: passo 17, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 17, imagem 2 %32
    • Remove the Phillips screws on both sides of the flash bulb mount.
  18. Nikon Coolpix E5700 Top Display Screen Replacement: passo 18, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 18, imagem 2 %32
    • Lift the top panel up and pull the flash bulb housing away from the rest of the top panel.
    • Note: The top panel will be difficult to separate from the flash bulb housing. Place your hands as shown in the picture and push upward with your thumb while holding the flash bulb housing stationary
  19. Nikon Coolpix E5700 Top Display Screen Replacement: passo 19, imagem 1 %32
    • Unplug the orange ribbon and the other wires and finish carefully removing the top panel.
  20. Nikon Coolpix E5700 Top Display Screen Replacement, Top Display Screen: passo 20, imagem 1 %32
    • Remove the black tape holding the wires to the cover.
  21. Nikon Coolpix E5700 Top Display Screen Replacement: passo 21, imagem 1 %32
    • Remove the two gold Phillips screws (3.9 mm) holding the white panel down.
  22. Nikon Coolpix E5700 Top Display Screen Replacement: passo 22, imagem 1 %32 Nikon Coolpix E5700 Top Display Screen Replacement: passo 22, imagem 2 %32
    • Remove display screen.
Conclusão
Kyle Sitton
Membro desde: 04/17/11
351 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 24-58, Amido Spring 2011 Membro de Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 2,654
