Introdução
This guide will walk you through the necessary steps to access and remove the LCD screen in the Nikon Coolpix E5700.
Peças
Não são necessárias peças.
  1. Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Use your finger tip to slide the battery release tab toward the battery symbol on the E5700.
    • Open the battery door.
  2. Pull the battery out of the E5700.
    • Pull the battery out of the E5700.
    • It may be necessary to wiggle the battery while pulling to free it from its pocket in the case.
    • Remove two Phillips screws (3.4 mm) located on the left side of the screen.
    • Remove two Phillips screws (3.4 mm) located on the right side of the screens.
    • Remove back plastic monitor cover.
    • Remove the Phillips screw on the top right side of the screen.
    • Carefully unplug the grey bundle of wires in the white housing.
    • Carefully unplug the small pink and wires in the grey housing.
    • Remove the two Phillips screws on the left side of the screen.
    • Remove the metal bar on the left side of the screen.
    • Remove the screen from the front plastic housing.
Conclusão
Uma outra pessoa concluiu este guia.
Kyle Sitton
333 reputação
7 Guides authored
Equipe
Cal Poly, Team 24-58, Amido Spring 2011 Membro de Cal Poly, Team 24-58, Amido Spring 2011
CPSU-AMIDO-S11S24G58
4 Membros
9 Guides authored
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Todo: 2,188
